TJ_Vreugdenhil
Cirrus
Dec 28, 2011Monitor send string
I am creating one pool with two pool members with two different IP's and ports, but I want to create a monitor that will check for both pool member host names? The problem is the VIP is going to be created in the future, so I can't match the URL name just yet. Is there a way to do this, or an alternative way? The config below is as follows on 10.2 software:
b monitor test_pool_monitor '{
defaults from https
interval 30
timeout 91
password "pass"
recv "Server Up"
send "GET /monitor/bigip.html HTTP/1.1 \nHost:examplesite1.test.com \nConnection: Close\n\n\r\n"
username "joe"
b pool test_pool '{
monitor all test_pool_monitor
members {
1.1.1.1:7111
2.2.2.2:7112
DNS: examplesite1 IP: 1.1.1.1 Ports: 7111
DNS: examplesite2 IP: 2.2.2.2 Ports: 7112
- nitass
Employee
not sure if i understand correctly. if you want to use different health monitor parameter, e.g. http host header, for each pool member, why won't you assign the monitor to pool member level instead of pool one?
e.g.[root@ve1023:Active] config b pool foo list pool foo { members { 200.200.200.101:80 { monitor myhttp1 } 200.200.200.102:80 { monitor myhttp2 } } } - arghh... you're right. Thank you!
- nitass
Employee
just curious since both pool members belong to one virtual server, shouldn't they support a common http host header e.g. examplesite.test.com? - nitass
Employee
sorry it is duplicated...
- The pool members do not belong to a Virtual Server as of yet. The only information I have at this point is the DNS names:
lclte00hpuiq1p.test.com
lclte00ipuiq1p.test.com
I do not believe I can match a common http host header without a VS, or any Header field? It would be nice to use one monitor for one pool, because I have many to do like this, but I do not see how.
I was thinking it could look like this:
b monitor test_pool_monitor_7111 '{
defaults from https
interval 30
timeout 91
password "pass"
recv "Server Up"
send "GET /monitor/bigip.html HTTP/1.1 \nHost:lclte00hpuiq1p.test.com \nConnection: Close\n\n\r\n"
username "joe"
b monitor test_pool_monitor_7112 '{
defaults from https
interval 30
timeout 91
password "pass"
recv "Server Up"
send "GET /monitor/bigip.html HTTP/1.1 \nHost:lclte00ipuiq1p.test.com \nConnection: Close\n\n\r\n"
username "joe"
b pool test_pool '{
members {
1.1.1.1:7111
monitor all test_pool_monitor_7111
2.2.2.2:7112
monitor all test_pool_monitor_7112
}' - Hamish
Cirrocumulus
You can use 1 monitor for HTTP/1.1 if the host header used is the same between the two hosts. It doesn't matter if a VS is created yet or not. That's independent. There's no connection between the VS and the monitor except that the status of the VS inherits the status of the default pool which is a result of the monitors results.
So if both your pool members respond with a host: header of mybestwebsiteever.com use that... or use what they think it will be when it goes live... As long as the host likes it, you're golden.
H
