Fincke's avatar
Fincke
Sep 09, 2019
making a monitor to work
I would like to make a monitor for a microservice webserver...
It dosent seems to be thar deficult, but it does not work for me..
eks. :
if I make an curl from the loadbalancer, I get an "OK" :
curl http://10.93.0.6:28080/ping
OK
but if I try to make an monitor, it fails ??
it is made like this (copy for bigip.conf) :
ltm monitor http /Common/swarm_ping {
  adaptive disabled
  defaults-from /Common/http
  destination *:28080
  interval 5
  ip-dscp 0
  recv OK
  recv-disable none
  send "GET /ping\r\n"
  time-until-up 0
  timeout 16
  • Fincke's avatar
    Fincke
    hi
    Yes I have tried to "insert" HTTP/1.0 or HTTP/1.1...
    did not help
  • hi
    what did the send strings look like when you converted them?
    also, have you tried enabling monitor logging for a few cycles to see what's occurring?
