LTM virtual machine offline
Hi dears all I've got offline issue in LTM virtual machine [root@F5-1:Offline] config. How could I resolve the problem.
regards
- Steve_LyonsRet. Employee
Hmm, can you please check the logs located at /var/log/ltm and provide its output?
- Sabeel_241529
Thanks Steve
Here is the log, really I don't have experience to analyse it.
Thu Dec 31 19:53:29 NZDT 2015noticeF5-1shutdown[10740]Thu Dec 31 19:53:29 2015 : shutting down for system halt on behalf of root Fri Jan 1 16:08:16 NZDT 2016noticeF5-1boot_marker---===[ HD1.1 - BIG-IP 11.3.0 Build 39.0 ]===--- Fri Jan 1 16:08:17 NZDT 2016noticeF5-1syslog-ng[2834]syslog-ng starting up; version=\'2.1.4\' Fri Jan 1 16:08:51 NZDT 2016noticeF5-1audispdaudispd initialized with q_depth=80 and 1 active plugins Fri Jan 1 16:08:52 NZDT 2016noticeF5-1syslog-ng[2834]Configuration reload request received, reloading configuration; Fri Jan 1 16:09:37 NZDT 2016noticeF5-1syslog-ng[2834]Configuration reload request received, reloading configuration; Fri Jan 1 22:00:41 NZDT 2016noticeF5-1shutdown[8898]Fri Jan 1 22:00:41 2016 : shutting down for system halt on behalf of root
- Samir_Jha_52506
Noctilucent
As per logs it looks root user fired
orhalt
command twice @NZDT(Fri Jan 1 16:08:16 NZDT 2016 & Fri Jan 1 16:08:16 NZDT 2016) and reload configuration twice. I guess you need to hard reboot deviceshutdown -h now
