LDAPS issue in F5 LTM
So here's our setup:
1.1.1.1:636
1.1.1.1:3269
1.1.1.1:389
1.1.1.1:3268
are the VIPs with pool of aba.abc.com, abb.abc.com, and abc.abc.com (yes they are in fqdn setup) port 636, 3269, 389, and 3268
Bot port 636 and 3269 have clientssl and serverssl profile while 389 and 3268 have none since these are non-ssl.
so upon testing using ldp.exe:
389 and 3268 working
636 and 3269 not working (ssl is checked on ldp.exe)
but if you try directly accessing the servers with ssl checked, it is working
Can anyone help or suggests what is needed to modify or where is the issue?
- Koalan
Cirrus
up
