Mitesh_378646's avatar
Mitesh_378646
7 years ago
Is there any way to check if Pool member are serving traffic or not.
Hi All, I am in a need where i do have 2 Pools one of them is serving traffic while other is not. The servers which is not serving traffic are also up & running, but just that not serving traffic ( due to iRule configured in a way).
Any API which can tell us this Pool or individual server is not serving traffic and its viceverse.
Any suggestion.
  • There are a few ways you can do that.
    One would be to log into the BIG-IP GUI and navigate to Statistics > Module Statistics > Local Traffic, and on the top drop down menu that says "Status Summary" select "Pools". Down below it will display your pools and if you click the + symbol to the left of the pool you are interested in, it will show the connections to each individual member.
    You can also run a tcpdump on the BIG-IP interface that faces your servers and filter the results using "dst host "
    Hope that helps!
    -Dylan
