Sulabh_Srivasta's avatar
Jun 23, 2021
iRule/policy for round robin traffic
Hi All,
I need help in setting up iRule/policy to loadbalance Round Robin traffic to two nodes listening on multiple ports.
Node - X.X.X.X listening on port 1001,1002,1003
Node - Y.Y.Y.Y listening on port 1001,1002,1003
Example : Client put in browser : https://www.abc.com/core/services,  LTM should send round robin traffic to :
https://X.X.X.X:1001/core/services/instance_1
https://X.X.X.X:1002/core/services/instance_2
https://X.X.X.X:1003/core/services/instance_3
https://Y.Y.Y.Y:1001/core/services/instance_4
https://Y.Y.Y.Y:1002/core/services/instance_5
https://Y.Y.Y.Y:1003/core/services/instance_6
Please let me know if this is possible with iRule, can this be done in same pool ??
Any help will be greatly appreciated.
Thank you.
  • Why don't you just add everything to a single pool as the F5 has no issues if the IP addresses of the pool members are the same ?
    From what I see you also need to rewrite the host and URI and maybe for this an irule will be needed (you can also use the "switch" way and not the "if" condition and you will need to add many elseif to match the other conditions):
    when LB_SELECTED {
    if {[LB::server addr] equals X.X.X.X && [LB::server port] equals 1001} {
    HTTP::header replace Host "X.X.X.X:1001"
    HTTP::uri "/core/services/instance_1"
    https://clouddocs.f5.com/api/irules/LB__server.html
    https://devcentral.f5.com/s/articles/irules-101-02-if-and-expressions
    https://clouddocs.f5.com/api/irules/switch.html
  • Also you haven't explained well what you want to do. For example if you want when the first request is send to X.X.X.X and you want the other requests from the same client to also be send to X.X.X.X but maybe on different port (round robin) look at the destination address persistance:
    https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-profiles-reference-12-1-0/4.html
    If you want that the requests after the first one to also be send to same ip address but also the same port then maybe Cookie or Universal or source persistance can be used.
    Also in my first reply I forgot to mention that if you also need to rewrite URL in the HTML payload not only the HTTP headers you will need to review the stream profile:
    https://support.f5.com/csp/article/K39394712
    https://support.f5.com/csp/article/K7027
  • As Nikoolayy1 indicated, BIG-IP LTM does allow pool members in a single pool to be configured with different IP addresses and/or different ports. The only reason you would need an iRule (or local traffic policy) is if you wanted to conditionally select the pool member to load balance to based on some part of the payload or if you want to modify the payload for the server-side request or client-side response in some way. For example, if you wanted to conditionally select the pool or pool member to load balance to based on the HTTP host name or parts of the HTTP URI, you will need to use an iRule or local traffic policy to set up the appropriate conditions and actions.
    You do not have to make any modifications to the HTTP host header unless the application server requires it. Otherwise, the host header will be passed unchanged from the client-side request to the server-side request by the BIG-IP system. In most cases, this is sufficient.
    Other considerations, such as persistence, are not reflected in your original question, so it is up to you to determine whether or not you need it (or other profiles) on the virtual server and in what form. Certainly, if you want to modify the HTTP payload in any way - request or response - you will need an HTTP-type profile on the virtual server.
