Habib_Ulla_Khan's avatar
Habib_Ulla_Khan
Oct 08, 2017
irule to decode using base64
Hi All,
Need help in irule. Currently using the below irule to capture username and password which is in plain text. The username/password is sent as query string in uri and this is working fine for me.
Query sent is like this : https://tryloginsso.help.com.ca?username=67580&password=login@123
Current irule is as below:
when ACCESS_SESSION_STARTED {
set username [URI::query [HTTP::uri] "username"]
set password [URI::query [HTTP::uri] "password"]
ACCESS::session data set session.logon.last.username $username
ACCESS::session data set session.logon.last.password $password
log local0. "vvvvv $username"
log local0. "vvvvv $password"
log local0. session.logon.last.usernam
As credentials sent is in plain text and concern about security. Query string is encoded using base64 as below from code. I want to write irule to decode the query string using base64 pass it for authentication.
var useridBytes = Encoding.UTF8.GetBytes(userId);
string userId_Encoded = Convert.ToBase64String(useridBytes);
var pwdBytes = Encoding.UTF8.GetBytes(pwd);
string pwd_Encoded = Convert.ToBase64String(pwdBytes);
Let me know what irule can be written to achieve this. Thanks in advance.
  • Hi,
    to decode base64, use the command:
    set userId_Encoded [b64decode $userId]
