zeesh86_123075's avatar
zeesh86_123075
Jun 12, 2014
Solved
irule performance issue
We recently got bought out and I had to redirect about 800 URI's. I wrote three irules to accomplish this because I was crossing the character limit for each irule. I noticed that the website took quite sometime to redirect and caused alot of performance issue for this. Is there any way around this?
  • You should be using data classes for this task. Something similar to..
      if {[class match [HTTP::uri] equals myclass]} {
         HTTP::redirect [class match -value [HTTP::uri] equals myclass]
    Then define a string data class with your redirect requirements.
    Name                  Value
    /home                 http://newhome.host.com/home
    /home2                http://otherhome.host.com
    Name                  Value
    • Kevin_Davies_40's avatar
      Kevin_Davies_40
      This can be easily adapted for hosts, use [HTTP::host] instead of [HTTP::uri] and the name in the data class becomes the host name. Also we used the matching expression "equals"... there is also starts_with, ends_with and contains for more flexibility.
  • shaggy's avatar
    shaggy
    In addition to Kevin's solution - newer versions of BIGIP handle data groups much more efficiently than older code levels, so perceived performance could also be impacted by the running code-level.
  • JG's avatar
    JG
    I would just have a VIP to take all these requests at the F5 device and pass them to an Apache server at the backend to do all these redirects, which is a lot easier to set up and maintain.
  • JG's avatar
    JG
    Well, at the minimum and at this point, it is easier to open a file of 600+ items with vi and do some global replacements there as needed, to me. :-)
    I used to have to handle 1200 URL redirects at one go that way in the past.
    But for each to his/her own way....
      Kevin_Davies_40
      Don't forget to tick the left of the post that provided the answer for you. This supports the volunteers who donate there time to help others on this site.
