mikegray_198028
Cirrus
Jan 19, 2017irule help
Hello Team,
I am looking for irule for the below scenario.
> for this user will submit client certificate with cn=user1 LB should accept this connection and reject all other connections.https://www.example.com/user1
> for this user will submit client certificate with cn=user2 LB should accept this connection and reject all other connections.https://www.example.com/user2
- JG
Cumulonimbus
Here's one in its simplest form:
when CLIENTSSL_CLIENTCERT { set subject_dn 0 Check if client provided a cert if { [SSL::cert count] > 0 } { set subject_dn [X509::subject [SSL::cert 0]] } } when HTTP_REQUEST { set user_in_path [string trim [HTTP::uri] "/"] if { ! ($subject_dn contains "cn=$user_in_path") } { reject } } - JG
Cumulonimbus
Would this one work for you:
when CLIENT_ACCEPTED { array set CNs {} } when CLIENTSSL_CLIENTCERT { for {set i 0} {$i < [SSL::cert count]} {incr i}{ log local0. "[IP::client_addr]:[TCP::client_port]: cert $i; subject=[X509::subject [SSL::cert $i]];\ [X509::issuer [SSL::cert $i]]; cert_serial=[X509::serial_number [SSL::cert $i]];" set CNs([X509::subject [SSL::cert $i]]) 1 } } when HTTP_REQUEST { switch -glob [HTTP::uri] { "/abcdef" { if { ! ([info exists CNs("cn=frontofficeuser")]) } { log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] : rejected." reject } } "/bcdefg" { if { ! ([info exists CNs("cn=hruser")]) } { log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] : rejected." reject } } "/cdefgh" { if { ! ([info exists CNs("cn=facilitiesuser")]) } { log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] : rejected." reject } } default { reject log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] : rejected." } } }?
- IheartF5_45022
Nacreous
Only the leaf cert, [SSL::cert 0] is used for client SSL checking. This should also work;-
when HTTP_REQUEST { set cn [class match -value [HTTP::path] starts_with dg_path_common_name_mapping] if {$cn ne ""} { Client certificate is required for this path if {![SSL::cert count]} { HTTP::respond 403 content "Client certificate required" noserver return } elseif {!([X509::subject [SSL::cert 0]] contains $cn)} { Client cert doesn't match required Common Name HTTP::respond 403 content "Client certificate does not match required name $cn" noserver return } } } - stan_piron
Cumulonimbus
you can use this irule:
when CLIENTSSL_HANDSHAKE { if {![info exists username]} {set username ""} } when CLIENTSSL_CLIENTCERT { Check if client provided a cert if { [SSL::cert count] > 0 } { set username [regsub -all ".*CN=(.\[^,\]*),.*$" [X509::subject [SSL::cert 0]] {\1}] } } when HTTP_REQUEST { if {[HTTP::uri] equals /} { HTTP::redirect "/$username" }elseif { !([HTTP::uri] starts_with "/$username") } { HTTP::respond 403 content { Not authorized You are not autorized to access this website } noserver } }
