iRule help - Routing traffic
Hello,
Is it possible once I implement the below iRule(25% percent of production web traffic being routed to staging_web pool) on our production web virtual server to then route all traffic from the staging_web pool to our staging_app pool of servers via the production app virtual server? The dev team does not want to change DNS entries once we do a deploy to staging then production.
when HTTP_REQUEST { if { rand() > 0.25 } { pool default-pool } else { staging_web } }
Thank you,
Interesting.
The ratio might not be exact (depending on the number of incoming connections and luck) but it could work. It ain't pretty though. :) Just don't forget to add "pool" in front of staging_web.
- Have you considered using ratio load balancing method?
- Or adding the staging web member to the pool with icontrol when you deploy?
- Or do a "rolling deploy" on one prod server at a time checking for errors that way.
- Or let the developers set a cookie when accessing the site and send them to the staging pool for testing in production?
Just a few suggestions.
/Patrik
- sysadmin_2015_2
Thank you for reply. Is there a better iRule or way to route 25% of production traffic to another pool of servers?
Thank you,
- sysadmin_2015_2
Awesome! Thank you so much for the help.
- sysadmin_2015_2
Sorry, One last thing. How would the iRule look if pool_1 was production and pool_2 was staging?
Thank you,
It'd be something like this:
when HTTP_REQUEST { if { rand() > 0.25 } { pool pool_1 } else { pool pool_2 } }Please note that unless you use connection multiplexing this rule would establish a new connection server-side every fourth request (more or less). If I were you I'd change the event to CLIENT_ACCEPTED because:
- Then the connections would not have to be re-established saving server performance.
- The iRule is only executed once per connection instead of once per request saving LTM performance.
Good luck!
/Patrik
- sysadmin_2015_2
Great, thank you!. I'll give it a try.
- No problem, glad to help!
- sysadmin_2015_2
Hello, Sorry for the delay, got pulled in another direction. But I have a couple of questions, I ran a JMeter test with a hundred threads(100 users) connecting to VirtualServer_01 and Pool_01_80. The test ran successful, under statics for VirtualServer_01 the Maximum connections showed 100 and it showed the same for Pool_01_80. Each pool has 5 web servers, during first test without iRule, each server showing 20 connections. I then cleared the statics and attached the below iRule to the virtual server. I then ran a second test with 100 threads(100 users). The virtual server showed 100 connection. Pool_01_80 showed 198 maximum connections and Pool_02_80 showed 51 maximum connections. Can you please tell me why the numbers seem off? I'm I reading it correctly? when HTTP_REQUEST { if { rand() > 0.25 } { pool Pool_01_80 } else { pool Pool_02_80 } } Thank you,
- weblead_151334
Patrick can you please review the post https://devcentral.f5.com/questions/i-rule-help-route-incoming-traffic-based-on-source-subnet-amp-url-contains-string-admin-or-intra & help me fix ...thanks!
- You've got two smart guys in there already and one is the legendary Joe. Rather not mess with their work and progress. :)
- weblead_151334
Still the syntax issue is n't resolved ...I would request immediate help to fix the issue ...
- sysadmin_2015_2
Hello,
Thank you,
- Been wrecking my brain, but I can't explain that one. In my lab I got 3 times more connections to Pool _01 compared to Pool_02. No other interfering iRules?
- sysadmin_2015_2
No, that's the only iRule I have applied.
Thank you,
