m00t's avatar
m00t
Apr 14, 2020
iRule for domain host replacement
Hey all,
I've been racking my brain trying to get a domain host replacement for a wildcard domain.
Trying to do anything:
*.domain1.com to redirect to *.domain2.com with the URI. Can't seem to do the replacement of the domain/hostname.. Any suggestions? I thought it would be simple, but proving not so much.
  • Are you trying to simply rewrite the domain of the host-header on an inbound request before it gets sent to a pool member?
    • m00t's avatar
      m00t
      Yep, want it to completely redirect to the other domain.
  • Hello,
    Please try below iRule,
       if { [HTTP::host] equals "domain1.com"} {
    HTTP::redirect "https://domain2.com[HTTP::uri]"
    Also you can even try to achieve this using policy.
    Hope it works !
    Mayur
  • m00t's avatar
    m00t
    Mayur, Thanks for that, but that just redirects a single domain1.com to domain2.com -- I need all the wildcard virtual domains to redirect too.. for instance site1.domain1.com to site1.domain2.com -- trying to do it without individual redirects for every virtual domain (thousands)
