iRULE execution order with data groups
Hello,
I have an iRULE like the one below, what would be the outcome if user with ip 192.168.168.168 accessed http://testserver2.abc.com
when HTTP_REQUEST{ switch -glob[string tolower [HTTP:host]]{ testserver1.abc.com{pool testserver1} testserver2.abc.com {pool testserver2} } if { [class match [IP:client_addr] equals external_users]} { pool testserver3 } }
ltm data-group external /Common/external_users{ records{ 192.168.168.0/24{} } type ip }
- JG
Cumulonimbus
The last pool member selection wins, i.e. 192.168.168.168 gets testserver3.
It would be better if you let us know what you are trying to achieve.
- youssef1
Cumulonimbus
First of you have this condition:
switch -glob [string tolower [HTTP:host]]{ testserver1.abc.com{pool testserver1} testserver2.abc.com {pool testserver2} }Depending the hostname that you enter, you will FW to a specific pool
- if hostname is testserver1.abc.com, you will forward to pool testserver1
- if hostname is testserver2.abc.com, you will forward to pool testserver3
Then you have an additional condition:
if { [class match [IP:client_addr] equals external_users]} { pool testserver3 }If you source IP is contain in the DG external_users as it happens "192.168.168.0/24" you will forward to pool testserver3.
In your case you enter the followin url http://testserver2.abc.com with source IP 192.168.168.168.
- So you will match first condition an your pool is set to testserver2
- but you match second condition due to your source IP and your pool it is finally configured to testserver3
Regards
