Vinne73's avatar
Vinne73
Icon for Cirrus rankCirrus
1 year ago
Solved
Invalid Content-Length header caused Big-IP to terminate connection?
Hi all,
I updated our Big-IP cluster to 17.1.1.4 last monday, and now I have a strange problem. When doing a HTTP request to any VIP, using POST but just as well GET or ..., and specifying an invalid "Content-Length" header, the Big-IP instantly terminates the connection as soon as the header is transmitted.
No error is logged in /var/log/ltm.
Examples:
Content-Length: haha
Content-Length: 2a
An empty Content-Length also causes the issue.
Curl example:
> User-Agent: curl/7.76.1
> Accept: */*
> Content-Length: aa
* OpenSSL SSL_read: Connection reset by peer, errno 104
* Closing connection 0
* TLSv1.2 (OUT), TLS header, Unknown (21):
I don't have any special iRules that might assume Content-Length is numeric. And then I would expect a TCL error.
Now my question: can anybody running 17.1.1.4 do a simple Postman-like request, and include an invalid Content-Length header? Does this work for you?
I would like to hear if others have this problem as well before I make a support case.
Yes I know invalid Content-Length headers are not ok, but clients should not be punished for it imo. And GET should not have Content-Length anyway, but then the Big-IP should just ignore it, right?
Thank you
Vincent
  • telnet 192.168.1.1 80
    Trying 192.168.1.1...
    Connected to 10.125.245.56.
    Escape character is '^]'.
    GET / HTTP/1.1
    Host: test
    Content-Length: abc
    Connection closed by foreign host.
    Same behavior in my environment. From which version do you upgrade?
    I think this behavior change was introduced with this bug fix:
    http://cdn.f5.com/product/bugtracker/ID1354253.html
    Validating headers is essential for security, but it is bad that there is no logging entry.
  • Hi
    i have running on 17.1.1.3 and only faced issues in optimized profiles. if you have issues, please check the 17.1.1.4 release note to verify it or raise a support ticket immediately to know the issue and fix
    BIG-IP 17.1.1.4 Fixes and Known Issues
    BR
    Aswin
    GET / HTTP/1.1
    Host: test
    Content-Length: abc
    • Vinne73's avatar
      Vinne73
      I think you are correct, this will be the cause probably. The article says it was fixed in 17.1.1, the version I'm coming from. So normally I should have already experienced the problem before, but I know these version are sometimes not 100% correct. But I was running engineering hotfixes on 17.1.1 for unrelated problems.
      I might contact F5 to see if there is a possibility to log this.
      Thanks.
