Robert_47833
Altostratus
May 11, 2011if,elseif,else, need help
set uri [HTTP::path]
set queryString [URI::query [HTTP::uri]]
set port [TCP::local_port]
set srcIP [IP::client_addr]
if {$uri equals "/"}
{ HTTP::redirect "http://m.srwd32.com/mobile/" }
elseif
{$uri starts_with "/myaccountapi/myaccount"}
{ persist none
pool SRWD32-MYX }
else{ if {$uri starts_with "/mobile/auth" and $port != 443 }
{ HTTP::redirect "https://[HTTP::host][HTTP::uri]"
log local0. "here i am 1 [HTTP::uri]" }
else
{ persist none
SSL::disable serverside
pool SRWD32-STATIC
log local0. "here i am 2 [HTTP::uri]" } } }
there is some issue in this irule
how to change it
if $uri is / go to http://m.srwd32.com/mobile/
if $uri starts_with "/myaccountapi/myaccount go to pool SRWD32-MYX
if {$uri starts_with "/mobile/auth" and $port != 443 go to https://[HTTP::host][HTTP::uri]
for other go to pool SRWD32-STATIC
I know I have mixed up by the realation of if ,elseif,else,..xo if......
Help me ?
- Michael_Yates
Hi jucao,
Try this and see if it works for what you are needing:when HTTP_REQUEST { switch -glob [ string tolower [HTTP::uri]] { "/" { HTTP::redirect "http://m.srwd32.com/mobile/" } "/myaccountapi/myaccount*" { persist none; pool SRWD32-MYX } } if { [[TCP::local_port clientside] != 443] && [[HTTP::uri] starts_with "/mobile/auth"] } { HTTP::redirect "https://[getfield [HTTP::host] ":" 1]/[HTTP::uri]" log local0. "here i am 1 [HTTP::uri]" } else { persist none SSL::disable serverside pool SRWD32-STATIC log local0. "here i am 2 [HTTP::uri]" } } - Michael_Yates
The "&" are &'s.
So it is & & (No Spaces). - hoolio
Hi Michael,
If you click Edit and then Save on your post the ampersands will be rendered correctly.
Aaron - Michael_Yates
Every time I have done that in the past it distorts the formatting of the entire post :-( - Robert_47833
Altostratus
Thanks ,it seems switch works more effective than if.elseif,else,right?
Any ,I found issue with this irule ,esle should be put behind },maybe it is sensitive to the } position.
elseif
{ persist none
pool SRWD32-MYX }
}else
{ persist none
pool SRWD32-STATIC
log local0. "here i am 2 [HTTP::uri]" } } } - hoolio
I think the problem is with no spaces before or after the elses:
}else
If you put spaces before and after the else statements it should load. But yes, the switch statement should be more efficient than the if/elseif/.../else chain.
Aaron - Colin_Walker_12Historic F5 AccountGenerally speaking we always encourage people to use switch over if/else chains where it makes sense. They're more efficient once you get past only a few if/else comparisons.
Colin
