Erika_I_Garner's avatar
Erika_I_Garner
Jan 30, 2018
IF-elseif-else irule issue
I am trying to add the last else so in case the cookie cookiecrisp then just send the traffic directly to the POOL_443 but it gives me an error. And I was wondering if someone can help me out with this issue
if { [HTTP::cookie exists cookiecrisp] } {
switch [HTTP::cookie value cookiecrisp] {
"azul" { if { [LB::status pool POOL-443 member 172.16.1.21 443] eq "up" } {
persist uie 1
} elseif {
[LB::status pool POOL-443 member 172.16.1.22 443] eq "up" } {
pool POOL-443
"rojo" { if { [LB::status pool POOL-443 member 172.16.1.23 443] eq "up" } {
persist uie 3
} elseif {
pool POOL-443
"amarillo" { if { [LB::status pool POOL-443 member 172.16.1.22 443] eq "up" } {
persist uie angel
} elseif {
pool POOL-443
pool POOL-443
Thank you so much!
Erika
  • Hi
    seems you forgot to close the switch statement right before the added $1 section. Below is the rearanged and already corrected code...
                "azul" {
                        persist uie 1
                    } elseif { [LB::status pool POOL-443 member 172.16.1.22 443] eq "up" } {
                        pool POOL-443
                "rojo" {
                        persist uie 3
                    } elseif { [LB::status pool POOL-443 member 172.16.1.21 443] eq "up" } {
                        pool POOL-443
                "amarillo" {
                        persist uie angel
                    } elseif { [LB::status pool POOL-443 member 172.16.1.23 443] eq "up" } {
                        pool POOL-443
            pool POOL-443
    Cheers, Kai
  • You can use following code (it assign the pool at the beginning to remove else statements):
        pool POOL-443
        set preferedMember [list]
            "azul" {
                set preferedMember  [list "172.16.1.21" 443 "172.16.1.22" 443]
            "rojo" {
                set preferedMember  [list "172.16.1.23" 443 "172.16.1.21" 443]
            "amarillo" {
                set preferedMember  [list "172.16.1.22" 443 "172.16.1.23" 443]
        foreach {memberip memberport} $preferedMember {
            if { [LB::status pool $default_pool member $memberip $memberport] eq "up" } {
                pool POOL-443 member $memberip $memberport
                break
    I'm not sure the persistence is useful! I guess you can remove it.
    The persistence record will match only is cookie value is the same as the previous request and the server is alive. so persistence is only done by cookie value.
