T_Rajneesh's avatar
T_Rajneesh
Aug 26, 2019
i-rule redirection issue
I have created a i-rule to redirect the when http host contains siteA, & uri starts with search, sent it to SiteA _3737pool.
if http host contains siteA, & uri has 'sales' or FinanceBuyCatergory' words, it has to send request to pool Finance_443 .
Else send request to default pool SiteA_443.
Kindly check and let me know if i'm doing something wrong in logic. I see the request are not being send to backend pools .
Note: Pool SiteA is attached to VIP where as pool Finance is not attached to VIP and acting a independent pool.
irule:
if { [HTTP::host] eq "SiteA" and ([HTTP::uri] starts_with "/search/") }{
  SSL::disable serverside
  pool SiteA_3737
 elseif { [HTTP::host] eq "SiteA" } {
  switch -glob [HTTP::uri] {
     "*sales*" -
     "*FinanceBuyCategory*" {
     pool Finance_443
 else { pool SiteA_443
  • Snl's avatar
    Snl
    you can achieve the same easily using LTM Traffic policy
    • T_Rajneesh's avatar
      T_Rajneesh
      Thank you,
      LTM Traffic Policy is not enabled in F5 box.
      Can you help on irule?
  • Hi T Rajneesh,
    Can you try this iRule?
    	if { ([string tolower [HTTP::host]] equals "sitea.com") or ([string tolower [HTTP::host]] equals "www.sitea.com") } {
    		switch -glob [string tolower [HTTP::uri]] {
    			"/search/*" {
    				log local0. "[HTTP::host] [HTTP::uri] iRule redirect SiteA_3737"
    				pool SiteA_3737
    			"*sales*" -
    			"*financebuycategory*" {
    				log local0. "[HTTP::host] [HTTP::uri] iRule redirect Finance_443"
    				pool Finance_443
    	log local0. "[HTTP::host] [HTTP::uri] iRule no redirect"
    	# if you use default pool, no need 'pool SiteA_443'
    	# pool SiteA_443
    If it doesn't work, can you check the logs?
  • HI,
    My first rule is working fine. i.e., search one.
    i have issue when uri has 'sales' or 'FinanceBuyCatageroy'.
    Regards,
    Rajneesh
