Wasfi_Bounni's avatar
Wasfi_Bounni
1 year ago
Solved
What happens if I only enable ASM in BIG-IP Under System > Resource Provisioning
Hi;
Let's say that I have a Big-IP device licensed for LTM and ASM. However, only the ASM module is enabled under System > Resource provisioning with a level of nominal.
I know that in this case, you can have a pool of only one member, but just to double check my information, I want to ask this questions:
Is my understanding above incorrect, and in this case, the system does load balance to multiple pool members, or I should enable the LTM module for this to happen?
Kindly
Wasfi
  • The LTM module must not be provisioned to enable the LTM features.
    Additionally, the current AWAF license (successor of the ASM license) integrates many LTM features: https://my.f5.com/manage/s/article/K14231234
