Saul_Andres_Riv's avatar
Saul_Andres_Riv
Jan 14, 2021
Solved
HTTPS health monitor with POST TMOS 13
Hello.
I am trying to configure the following POST monitor but it is not working.
ltm monitor https MON_HTTPS_TEST {
  adaptive disabled
  defaults-from https
  destination *:*
  interval 5
  ip-dscp 0
  recv "HTTP/1.1 200 OK"
  recv-disable none
  send "POST /web-e/AutenticationFi HTTP/1.1\r\nHost: test.example.com\r\nAccept: */*\r\nContent-Length: 431\r\nContent-Type: application/xml;charset=ISO8859-1\r\n\r\n <TCFX> <HeaderRq TRNUID=\"830709062778379\" SESSCOOKIE=\"7cf5b287-9cc4-4fa2-af87-dbd3461c9e4d\" BANKID=\"0015\" APPID=\"AW0718001\" DATECREATED=\"2021/01/08 05:03:26\" CLIENTIP=\"190.66.208.17\" CONTRACTTYPE=\"SVEPLUS\" CUSTOMERTYPE=\"FS003\" CUSTOMERID=\"2020092901\" USERTYPE=\"FS003\" USERID=\"2020092901\" USERNAME=\"2020092901\" LANG=\"ES\" CHN=\"002\" SCHN=\"2\" UNIQUEID=\"830709062778379\"/> <SumyRq SUMYTYPE=\"ALLACCOUNTS\" SUMYTIME=\"REAL\"></SumyRq></TCFX>"
  time-until-up 0
  timeout 16
If I perform the cURL it gives me the expected response successful
curl -vk -X POST https://test.example.com/web-e/AutenticationFi -H Content-Type: 'application/xml;charset=ISO8859-1' -d '<TCFX> <HeaderRq TRNUID="830709062778379" SESSCOOKIE="7cf5b287-9cc4-4fa2-af87-dbd3461c9e4d" BANKID="0015" APPID="AW0718001" DATECREATED="2021/01/08 05:03:26" CLIENTIP="190.66.208.17" CONTRACTTYPE="SVEPLUS" CUSTOMERTYPE="FS003" CUSTOMERID="2020092901" USERTYPE="FS003" USERID="2020092901" USERNAME="2020092901" LANG="ES" CHN="002" SCHN="2" UNIQUEID="830709062778379"/> <SumyRq SUMYTYPE="ALLACCOUNTS" SUMYTIME="REAL"></SumyRq></TCFX>'
ANSWER
> User-Agent: curl/7.47.1
> Accept: */*
> Content-Length: 431
* upload completely sent off: 431 out of 431 bytes
< HTTP/1.1 200 OK
< X-Powered-By: Servlet/3.1
< Content-Language: en-US
< Date: Thu, 14 Jan 2021 15:45:41 GMT
< Transfer-Encoding: chunked
Any idea why the health monitor is not working?
Thanks a lot
  • Mmm interesting,,, well your conversion seems to be properly done, wherever required, special chars have been escaped. I could think of 2 possibilities, please test it and tell us or turn on logging & check it.
    1. If the content length is not matching, the requests would not work as expected. Try without this.
    2. Try removing this header Content-Type: 'application/xml;charset=ISO8859-1' & test it with a simple -H "Content-Type: application/json", i dont know if the semi-colon is also considered as a special char (after xml & before charset) & requires to be escaped.
    So give it a shot.
  • Hi,
    Thanks for your reply
    I did what you suggested but it was not successful.
    1. First, I removed the Content-Length
    2. Second, I changed the Content-Type
    The monitor continues to mark the pool down
    • jaikumar_f5's avatar
      jaikumar_f5
      Icon for Noctilucent rankNoctilucent
      As a temp solution, you can go with external monitor, use the same curl cmd & capture the output.
      Put an if condition to see if it matches the result & then echo Up.
  • Hi,
    Thanks for your help.
    It was not necessary to apply an external monitor (which I was concerned about a reported vulnerability)
    With F5 Support, the following could be validated:
    "HTTP monitors with POST typically fail when the Content-Length header is incorrect, which makes the receiving side parser out of sync with the sender - I can see a hint of why it was miscounted.
    The command line:
    -H Content-Type: 'application/xml;charset=ISO8859-1' -d '<TCFX> <HeaderRq TRNUID=....
    Indicates the post data (-d) is starting directly with the < character, however, in the configuration, and in the logs, there's still an extra space:
     <TCFX> <HeaderRq ...
    This space is also visible in the logs:
    [0][13255] 2021-01-14 10:29:33.071367: ID 1151 :(_send_active_service_ping): writing ....xml; charset=ISO8859-1\x0d\x0a\x0d\x0a <TCFX> <He
    The (successful) POST seem to be indeed 431 bytes long, however, the monitor as configured seem to contain an additional space making the body 432 bytes long"
    So, I just removed the extra space before <TCFX> and it worked
    Thats great to hear its resolved. I knew it would be something on content length 🙂
    Can you mark your answer as solution.
