How to update/delete the attribute of an object using F5 SDK
Hi all,
I would like to ask for an advice> I would like to update/delete the attribute of an object .
From this collection : mgmt.tm.net.selfips.get_collection() i would like to update : selfip.allowService
I noticed that for example when selfip.allowService is set to allow none from GUI this attribute allowService is missing from selfip.raw output So if i want to set this attribute to none in case it has allow all should i update the attribute to none or delete the attribute ?
Would you please advise and also recommend some documentation to read to better understand the update/delete process?
Regards,Vlad
- Satoshi_Toyosa1Ret. Employee
I believe you are after an iControl REST method equivalent to the following tmsh:
tmsh modify net self allow-service none
In iControl REST, use an empty list [] for none. A curl example is shown below. The same method should work for Python SDK too.
curl -sku admin: https:///mgmt/tm/net/self/-H "Content-Type: application/json" -X PATCH -d '{"allowService":[]}'
- Satoshi_Toyosa1Ret. Employee... and a sample python code.The code becomes complex because the data type of the allowService field value depends on what you specify.Allow All is a string: 'all'Allow default is a list containing the string default: ['default']Allow none is represented by absence of the allowService field.The code is not sophisticated and there should be a better way, but at least it does the job for you.
!/usr/bin/env python from f5.bigip import ManagementRoot mgmt = ManagementRoot('xx.xx.xx.xx', 'admin', 'adminPass') def showSelfIp(str): selfIp = mgmt.tm.net.selfips.get_collection() selfIpList = {ip.raw['name']: ip for ip in selfIp} print('--- {}'.format(str)) for ip, obj in selfIpList.iteritems(): try: allowService = obj.raw['allowService'] except KeyError: allowService = 'None' allowServiceType = type(allowService) print('{:<20}{:<20}{}'.format(ip, allowService, allowServiceType)) return selfIpList # Get a list of selfIP selfIpList = showSelfIp('Before') # Change allowService of 'vmnet1-self' from 'all' to 'default' ([list]) selfIp1 = selfIpList['vmnet1-self'] selfIp1.raw['allowService'] = ['default'] selfIp1.update() selfIpList = showSelfIp('vmnet1-self to default') # Change allowService from 'default' to 'all' (string) selfIp2 = selfIpList['vmnet2-self'] selfIp2.raw['allowService'] = 'all' selfIp2.update() selfIpList = showSelfIp('vmnet2-self to all') # Change allowService from 'default' to 'None' (no field) selfIp3 = selfIpList['vmnet3-self'] del selfIp3.raw['allowService'] selfIp3.update() selfIpList = showSelfIp('vmnet3-self to None') # Done
