pratik_kale_359's avatar
pratik_kale_359
Jun 09, 2018
How to resolve VIP down issue
  • Hi
    In normal case. If when VIP down, both Active-Standby bigip alert VIP down, this symptom is not related with server. or network problem between BIGIP and Server. Backbone or L2 switch or etc.
    And check server`s teaming log. and using vmac.
    If VIP is using HTTP or HTTPS, set monitor gateway icmp and http/https both.
    set monitor tcp(or http) and icmp help how to solve problem.
    When this kinds of solution didn`t help, set tcpdump before problem occured.
    Set 1 PC and command tcpdump not using -w option and set log session on your terminal program.
    When event occured, analyze tcpdump log.
    have a good day.
    • swjo_264656's avatar
      swjo_264656
      If you need reduce down time.
      Set i-rule likewise this.
      when client_accepted { if { pool mypool active_members < 0 } virtual second_VIP }
      I didn`t remember correct syntex, but this rule is very easy.
      search devcentral and test once and apply.
      have a good day.
      swjo_264656
      If you using http profile.
      set Fallback host option.
