breizho35_11667
Feb 08, 2010How to read source IP and write http header ?
Hello,
since commencing in iRules, I seek your help to write a script to meet this need:
when HTTP_Request (
- Read source IP address (eg 192.168.100.101) and translate this source IP in a digit code number of 10 characters without point (eg 2168100101)
- Include a http header corresponding to this digit code (eg TOTO: 1234567890).
HTTP::header insert "TOTO" "digit code"
Please, can you help me to write this script?
Thanks you for your help,
Eric
- The_Bhattman
Hi Eric,
The following is a untested iRule that may work for youwhen HTTP_REQUEST { Create the variable that will be used to later to store the IP address with the dots set ipaddr Scan command looks at the source address in [IP::client] and breaks it up into 4 variables oct1 to oct4 scan [IP::client] {%[^.].%[^.].%[^.].%s} oct1 oct2 oct3 oct4 append takes all the variables oct1 to oct4 and puts them together into another variable called ipaddr append $ipaddr $oct1 $oct2 $oct3 $oct4 The command below inserts a header called TOTO with the value of what's in ipaddr [HTTP::header] insert "TOTO" $ipaddr }
I have made comments in the code so you understand the logic behind it
I hope this helps
Bhattman - hoolio
I think the poster is trying to convert the client IP to a decimal value, along the lines of the PHP ip2long function. I was playing around with such a conversion in TCL, but it seems to overflow a 2^32 integer:
This works. Returns 2130706433
set ip 127.0.0.1
This works. Should return 377299345
set ip 22.125.33.145
This does not work. Should return 4211081210
set ip 250.255.255.250
scan $ip {%d.%d.%d.%d} a b c d
set dec [expr {[expr {$a <<24}] + [expr {$b <<16}] + [expr {$c <<8}] + $d }]
Anyone have suggestions on converting a dotted IP address to decimal format?
Aaron - hoolio
Actually, maybe not. Maybe he just wants the periods removed and to take the last 10 characters? If so, something like this should work too:when CLIENT_ACCEPTED { Remove the .'s from the client IP and take the last 10 digits set ip_string [string map {"." ""} [IP::client_addr]] set ip_string [string range $ip_string [expr {[string length $ip_string] - 10}] end] } when HTTP_REQUEST { Insert the HTTP header HTTP::header replace TOTO $ip_string }
Aaron - breizho35_11667
Hello,
thank you very much for your help, I'll try and tell you again.
Best regards,
Eric
