posiczko_73022's avatar
posiczko_73022
Jan 18, 2008
How to modify IP payload (UDP checksum)?
Hello,
This may be a novice question, but how does one modify IP payload? I need to modify UDP checksum in a packet, alas this seems close to impossible. UDP has UDP::payload, as does TCP, but IP doesn't?
Would replacing the payload with original payload force calculation of a checksum, like so:
when CLIENT_DATA {
set length [UDP::payload length]
set payload [UDP::payload]
UDP::payload replace 0 0 $payload
Thanks!
Pawel
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    Hi Pawel -
    We don't yet have the ability to manipulate L3 payload / L4 headers.
    I'm not sure if replacing the payload would recalculate the checksum, but it's worth trying.
    /deb
