James_Thomson
Employee
Aug 23, 2007how to findclass with client IP matching string
I trying to write an iRule for a wildcard virtual server that will look at the client's IP address, then find out what subnet it is in by looking at a class to see where it maps. I don't need a "most specific" match because nothing will overlap.
This rule is doing exactly what I need it to do:
when CLIENT_ACCEPTED {
if { [IP::addr [IP::remote_addr] equals "10.10.10.0/24"] ne 0} {node 10.10.10.1}
elseif { [IP::addr [IP::remote_addr] equals "10.10.230.0/25"] ne 0} {node 10.10.11.1}
elseif { [IP::addr [IP::remote_addr] equals "10.20.0.0/16"] ne 0} {node 10.10.12.1}
elseif { [IP::addr [IP::remote_addr] equals "10.10.22.0/24"] ne 0} {node 10.10.13.1}
elseif { [IP::addr [IP::remote_addr] equals "10.10.14.0/24"] ne 0} {node 10.10.14.1}
elseif { [IP::addr [IP::remote_addr] equals "3.0.0.0/8"] ne 0} {node 10.10.15.1}
elseif { [IP::addr [IP::remote_addr] equals "10.10.16.0/24"] ne 0} {node 10.10.16.1}
elseif { [IP::addr [IP::remote_addr] equals "10.10.17.0/24"] ne 0} {node 10.10.17.1}
elseif { [IP::addr [IP::remote_addr] equals "10.10.18.0/24"] ne 0} {node 10.10.18.1}
elseif { [IP::addr [IP::remote_addr] equals "10.10.19.0/24"] ne 0} {node 10.10.19.1}
else { discard }
}However, I would like to try and get these subnets into a class instead of in the iRule itself.
So, I tried a class and rule like this:
class mapping {
"10.10.10.0/24 10.10.10.52"
"10.10.10.0/255.255.255.0 10.10.10.51"
rule match-trying {
set my_gw [findclass [IP::client_addr] $::mapping " "]
log local0. "node $my_gw"
if { $my_gw ne "" } {
node $my_gw
} else { discard }
}but a findclass won't work because the IP I pull from IP::client_addr is a specific address while I have a subnet in the class. Worse off is the subnet in the class is a string so I can't use IP::addr to compare the two.
The previous rule logs nothing.
That is why this returns nothing, because it doesn't string match. The subnets are not always the same so I can't assume that.
I found a few other posts that are so close, but not right.
http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&forumid=5&postid=7784
http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&forumid=5&postid=3691
Any ideas?
- hoolio
As you found, I don't think it will work with a single class. You could create two classes and then use matchclass and findclass. Or you could create an array with three elements (network, mask, gateway) and use IP::addr with the client IP and the first two elements to find a match.
Here's a quick example for using two classes:when RULE_INIT { log local0. "\$::address_class: $::address_class" log local0. "\$::gw_class: $::gw_class" log local0. "\[matchclass 10.100.0.1 equals \$::address_class\]: [matchclass 10.100.0.1 equals $::address_class]" log local0. "[findclass [matchclass 10.100.0.1 equals $::address_class] $gw_class " "]" log local0. "\[matchclass 192.168.2.2 equals \$::address_class\]: [matchclass 192.168.2.2 equals $::address_class]" log local0. "[findclass [matchclass 192.168.2.2 equals $::address_class] $gw_class " "]" }
With two classes:class address_class { network 10.0.0.0 mask 255.0.0.0 network 172.16.0.0 mask 255.240.0.0 network 192.168.0.0 mask 255.255.0.0 }class gw_class { "1 10.1.1.1" "2 172.16.0.1" "3 192.168.0.1" }
The log output is:$::address_class: {10.0.0.0/8} {172.16.0.0/12} {192.168.0.0/16} $::gw_class: {2 172.16.0.1} {1 10.1.1.1} {3 192.168.0.1} [matchclass 10.100.0.1 equals $::address_class]: 1 10.1.1.1 [matchclass 192.168.2.2 equals $::address_class]: 3 192.168.0.1
With that said, an array might be a cleaner solution.
Aaron
