How to determine TCP::payload replace offset value
Hello,
I am looking to use TCP::payload replace to change a server response but need assistance with figuring out how to determine the offset. There is a preamble before the string I need to replace and I need to maintain that. Here's what I have so far:
when SERVER_CONNECTED {
TCP::collect
when SERVER_DATA {
set sdata [TCP::payload]
if { $sdata contains "foo.bar.com:8080" } {
log local0. "sdata found: $sdata"
TCP::payload replace 0 [string length $sdata] "widget.com:8080"
TCP::release
TCP::collect
Of course the '0' in 'TCP::payload replace 0' will start the replacement at the beginning of the server data response which does not work.
How would I determine where in the server data response 'foo.bar.com:8080' starts, which is what I believe the offset value is for?
Hi Bob,
you may try a
to find the "first" position of this string.[string first "foo.bar.com:8080" $sdata]Cheers, Kai
