How to add VLAN in tenant on F5r2600 running F5OS?
Hi
I have F5 r2600 running F5-OS 1.3.x and we deploy 1 tenant (BIG-IP 15.x)
We want to add a new VLAN on this tenant.
But I think I heard that we need to assign VLAN on F5-OS (Host/Hypervisor) instead of create on BIG-IP tenant
Is that correct?
Thank you
Hi kridsana,
- Network Settings > VLANs
Create new vlan. - Network Settings > Interfaces
Bind the vlan to the interface. - Tenant Management > Tenant Deployements
Select the vlan on tenant.
The vlan will be automatically added to the bigip tenant. No need to restart tenant.
- Leslie_HubertusRet. Employee
kridsana - if the reply from Enes_Afsin_Al helped you out, please be sure to click the Accept as Solution button so others can easily find the same help in the future. 🙂
Hi kridsana,
