Hotfix-BIGIP-13.0.0.2.0.1671 failed due to a DoS configuration issue
After installing Hotfix-BIGIP-13.0.0.2.0.1671-HF2.iso , i have faced the below issue and the configuration file didn't load completely :
******* output of tmsh load /sys config verify *****
01071aa7:3: Dos Device attack data bad actor per-source detection/limit pps cannot be greater than the Dos vector (icmpv4-flood) rate threshold setting for /Common/dos-device-config. Unexpected Error: Validating configuration process failed.
any suggestion how to fix it ?
this is a bit tricky, but if you are familiar enough with the CLI you can do this:
- edit the bigip.conf to make sure that doesn't occur, search for dos-device-config and see if you can find it and then do a tmsh load sys config
else you can rollback and try to solve it in the GUI on the old version and then upgrade again.
