jj24_43946's avatar
jj24_43946
Jun 17, 2011
Help with LocalLB::Pool/set_monitor_association
Hi again,
I think I'm on the last hurdle here. Trying to associate a health monitor with a pool. I think I've built the DS according to the ref: http://devcentral.f5.com/wiki/default.aspx/iControl/LocalLB__Pool__set_monitor_association.html.
BUILD DS
my ( @MonitorAssociationA, @MonitorAssociationAofA );
my $MonitorRule = {
type => "MONITOR_RULE_TYPE_SINGLE",
quorum => 0,
monitor_templates => [$f5_template_name]
my $MonitorAssociation = {
pool_name => $f5_pool_name,
monitor_rule => $MonitorRule
push @MonitorAssociationA, $MonitorAssociation;
push @MonitorAssociationAofA, [@MonitorAssociationA];
my $soapResponse = $Pool->set_monitor_association(
SOAP::Data->name(monitor_associations => [@MonitorAssociationAofA])
When I run the script, however, I see:
$ ./associateMonitor.pl
SOAP-ENV:Server Could not find element by name: pool_name
The pool_name is definitely defined though:
$VAR1 = [
'monitor_rule' => {
'type' => 'MONITOR_RULE_TYPE_SINGLE',
'quorum' => 0,
'monitor_templates' => [
'https_test_pool2_monitor'
'pool_name' => 'test_pool2_443'
Once again, any help would be much appreciated. Thanks!
Justin
  • Aha, I figured it out. I had a level in the nested array that was empty. Removed that level and it works. Thanks anyway!
  • Great, it's always better when you figure it out yourself. That way if you get into the problem again, you'll have something to reference.
    Using the Perl interfaces does take a little learning curve to figure out how to formulate all the parameters. Keep in mind that the stronger typed languages (.Net, Java) have bindings setup so you don't have to do so much packaging of structure/etc.
    -Joe
  • Hi there,
    I am having exactly the same problem. Would you mind posting the Data::Dumper output of your new structure?
    Many thanks,
    Hayato
    • Grain_131632's avatar
      Grain_131632
      the new structure: $VAR1 = { 'monitor_rule' => { 'type' => 'MONITOR_RULE_TYPE_SINGLE', 'quorum' => '0', 'monitor_templates' => [ 'https' ] }, 'pool_name' => 'testabc-pool' };
  • I've figured it out now! I'm still getting used to it but I'll get there soon!
  • Hello,
    I am hitting the same issue except with JAVA, any ideas?
    monitorAssociationLocalLBPoolMonitorAssociation (id=66)
    __equalsCalcnull
    __hashCodeCalcfalse
    monitor_ruleLocalLBMonitorRule (id=67)
    __equalsCalcnull
    __hashCodeCalcfalse
    monitor_templatesString[1] (id=65)
    [0]"AA-passive" (id=68)
    count10
    hash-1652696102
    offset0
    valuechar[10] (id=74)
    quorum0
    typeLocalLBMonitorRuleType (id=47)
    _value_"MONITOR_RULE_TYPE_AND_LIST" (id=75)
    count26
    hash-519180115
    offset0
    valuechar[26] (id=76)
    pool_name"test-pool" (id=71)
    count10
    hash1541172179
    offset0
    valuechar[10] (id=72)
