Mr_Moody's avatar
Mr_Moody
Oct 30, 2020
Solved
Help with IRule Client Auth Certs
I have an IRule below that I'm working on. My intent is to enforce client certificate authentication on two URI's only and if any client certificate errors should result in a redirect to a custom error page. The VS has a SSL profile set to 'ignore' client certificates. This rule successfully processes the first two 'If' statements. The problem is that the custom error page is not displayed. Any help would be appreciated.
	if { not ([HTTP::uri] starts_with "/uri1") || ([HTTP::uri] starts_with "/uri2")} {
			return
if { ([HTTP::uri] starts_with "/uri1") || ([HTTP::uri] starts_with "/uri2")} {
		SSL::session invalidate
    SSL::authenticate always
    SSL::authenticate depth 9
    SSL::cert mode require
    set cmd "SSL::profile /Common/require_clientssl"
    eval $cmd
    SSL::renegotiate
if {[SSL::verify_result] == 0 }{
			return
HTTP::respond 302 Location "http://error.com/error.html" Cache-Control No-Cache Pragma No-Cache
I have another rule that meets two of the three requirements. With the VS SSL profile set to 'request' client certs. This rule does provide a custom error page when Cert errors occur on the two named URI's. But it also results in a certificate prompt for users who access other URI's due to the default SSL profile setting.
			return
			return
  • Your HTTP::respond 302 is in the else clause of your second if statement.
    It is never reached.
                            # This path has no client-authentication
    			return
          # perform client-authentication if the uri matches
            eval $cmd
            SSL::renegotiate
            # we cannot execute this path because of the first *if* statement
    			return
    Try something like
          # we don't need to renegotiate with client-authentication
    	  return
          # we do need to renegotiate with client-authentication
          eval $cmd
          SSL::renegotiate
          # check if renegotiation with client-auth succeeded
    		return
    but I haven't tested this to check ...
    			return
            eval $cmd
            SSL::renegotiate
    			return
    Try something like
    	  return
          eval $cmd
          SSL::renegotiate
    		return
    • Mr_Moody's avatar
      Mr_Moody
      Thank you that was it! I also had to change the cert mode to 'request'.
