rhino_109458
Jan 18, 2012help on irule redirect
hello
f5 noob here
i have a machine running different virtual servers
i want to make a simple redirect to a speciffic URL and found this on some other posts
when HTTP_REQUEST
if { [HTTP::host] equals https://aaa.com} { HTTP::redirect https://aaa.com/hello }
though i get no errors when saving the irule typing in the browser https://aaa.com i get to my custom error page
on the log i can see that there was a block on /
seems to me the irule is not working
some help please?
thanks
- hoolio
Hi Rhino,
Try adding a check of the URI so you only redirect / to /hello. Also the host header won't have the protocol in it.when HTTP_REQUEST { if { [string tolower [HTTP::host]] eq "aaa.com" and [HTTP::path] eq "/"} { HTTP::redirect https://aaa.com/hello } }
Aaron - rhino_109458
hello hoolio
thanks for the reply freaking fast :)
i copied your solution and changed the host and uri but im still getting kicked by policy to default page
from log:
Requested URL [HTTPS] /
any thoughts ? - hoolio
What do you mean by "by policy to the default page"? Can you try testing with curl from the LTM command line to the virtual server and reply with the output?
For http
curl -v http://1.1.1.1/
For https
curl -vk https://1.1.1.1/
erm i wrote i am a noob should have written N000B :)
i dont realy have experience with CLI and i know this machine is acting up so id rather not do anything in CLI
but the situation is:
i have a virtual server up and running policy configured in blocking and i have made a custom block page .
the application on the server is listens to https://aaa.com/hello
my allowed urls are relative to the above URL
all i really need is to redirect traffic comming from https://aaa.com to https://aaa.com/hello
without opening / in the url policy list
hope i explained clearly - hoolio
So you're using ASM and getting blocked because the / URI isn't defined in the policy? Out of curiosity, why don't you want to define / as an allowed URL in the ASM policy?
I thought the redirect in HTTP_REQUEST would prevent ASM from validating the request. With the iRule enabled, do you see the / request being blocked in the ASM forensics?
By the way, testing this from the command line wouldn't have any impact on the state of the box. It's functionally equivalent to testing to the virtual server from a browser.
yes hoolio after adding the rule / still got blocked.
following your last post i added / to the allow list
trying https://aaa.com i got to the servers iis page with the url pointing to https://aaa.com/wellcome.png
using http watch i could not see a redirect to https://aaa.com/hello
this post got kinda messy and a 2 way only conversation hope folks reading this are not bored :P - hoolio
Can you try adding some debug logging and reply back with the logs? You can check for the output under /var/log/ltm or in the GUI under System | Logs | Local Traffic. If you put the logs in [ code ] [/ code ] tags (without the spaces) the event names in the logs will be preserved.when HTTP_REQUEST { log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::method] request to [HTTP::host][HTTP::uri]" if { [string tolower [HTTP::host]] eq "aaa.com" and [HTTP::path] eq "/"} { log local0. "[IP::client_addr]:[TCP::client_port]: Redirecting to https://aaa.com/hello" HTTP::redirect https://aaa.com/hello } } when HTTP_CLASS_SELECTED { log local0. "[IP::client_addr]:[TCP::client_port]: Matched [HTTP::class]" }
getting error when saving the rule
bigip 10.2.1
01070151:3: Rule [fotoweb_redirect] error: line 8: [unknown event (HTTP_CLASS_MATCHED)] [when HTTP_CLASS_MATCHED { log local0. "[IP::client_addr]:[TCP::client_port]: Matched [HTTP::class]" }] - hoolio
Sorry, that should have been HTTP_CLASS_SELECTED instead of HTTP_CLASS_MATCHED. I updated the example above.
after the fix :
rule is correct but i am still getting the IIS main page with no redirect
under local traffic log there are only events regarding downed pools and non related notices nothing that contains the string aaa.com
checked it through the GUI and var/log/ltm
