Need Irule for redirection for port translation
Hello team,
I am trying to configure one web service. Post configuration when i tried to access service using F5 VS, the requests redirected to the http host with automatically addition of service port 8080 which is backend webserver port.
e.g. i was trying to access web service using https://abc.com --> it got redirected to http://abc.com:8080
I am sure, F5 is not adding this port. This is happening due to hard coded port from application itself but application team member is not able to find it under application config. I am looking for an iRule which will help to redirect 'http://abc.com:8080' to https://abc.com again.
I tried several which are available on internet but somehow not working for me. Please help me here.
Hello Vikash,
Please try below iRule -
if { [string tolower [HTTP::host]] contains "abc.com" } {
pool abc-pool
HTTP::header remove Accept-Encoding
STREAM::disable
when HTTP_RESPONSE {
# Disable the stream filter for server responses
STREAM::disable
# Enable the stream filter for text responses only
if {[HTTP::header value Content-Type] contains "text"}{
# Replace 'old_text' with 'new_text'
STREAM::expression {@http://abc.com:8080/@https://abc.com/@}
# Enable the stream filter for this response only
STREAM::enable
Hope it works for you!
Mayur
Hello Vikash,
pool abc-pool
STREAM::disable
STREAM::disable
STREAM::enable
Mayur
- VikashC
Cirrus
Thanks Mayur!
I will try above iRule and update you.
- VikashC
Cirrus
It worked perfectly for me!! Thanks for the help, appreciate it !!
Just one question here, if i want to add one more host redirection in the same iRule then how will be the formatting? This is because, mostly we have multiple host traffic behind one VS. So we have commons iRules. e.g. under above iRULE itself, i want to add redirection from http://xyz.com:8080 to https://xyz.com.
What will be my iRule?
Hello ,
Either you can have separate iRule for each host URL and attached all such iRules to the required Virtual Server or
You can add all the URLs under single iRule as given below -
pool abc-pool
}elseif { [string tolower [HTTP::host]] contains "xyz.com"} {
pool xyz-pool
STREAM::disable
STREAM::disable
STREAM::expression {@http://abc.com:8080/@https://abc.com/@\
@http://xyz.com:8080/@https://xyz.com/@}
STREAM::enable
I have highlighted additional changes for other url. You can compare both iRules to get clarity. This way you can have multiple re-directions for multiple URLs under same iRule.
Thank you,
Mayur
- VikashC
Cirrus
Okay, got it.
