midhun_108442
Jan 21, 2012Nimbostratus
Help need to create a irule for limit Client Connection
Can anyone help us to create a irule to limit number of client connection hitting to Virtual server , I got the same irule scenario in Dev central site for (iRule.Limit Connection from Client) , but thats not working with me its only logging the message not blocking the connection ,Kindly anyone help me to provide the irule for the same.
Regards,
Midhun P.K
- hooleylistCirrostratusYou can take Thomas's logic and store the hosts and/or networks in a data group with the values set for the connection limit.
Data group mapping hosts/networks to connection limit values class conn_limit_dg { network 10.0.0.0/8 { "5" } network 192.168.0.0/16 { "5" } host 172.16.1.1 {"10"} }
From http://devcentral.f5.com/wiki/iRules.table.ashx Limit each client IP address to 20 concurrent connections when CLIENT_ACCEPTED { Max connections per client IP set limit [class match [IP::client_addr] equals conn_limit_dg] Set a subtable name with a standard prefix and the client IP set tbl "connlimit:[IP::client_addr]" Use a key of the client IP:port set key "[IP::client_addr][TCP::client_port]" Check if the subtable has over X entries if { [table keys -subtable $tbl -count] >= $limit } { log local0. "[IP::client_addr]:[TCP::client_port]: Rejecting connection ([table keys -subtable $tbl -count] connections / limit: $limit)" reject } else { Add the client IP:port to the client IP-specific subtable with a max lifetime of 1800 seconds (30min) table set -subtable $tbl $key "ignored" 1800 log local0. "[IP::client_addr]:[TCP::client_port]: Allowing connection ([table keys -subtable $tbl -count] connections / limit: $limit)" } } when CLIENT_CLOSED { When the client connection is closed, remove the table entry table delete -subtable $tbl $key log local0. "[IP::client_addr]:[TCP::client_port]: Decrementing ([table keys -subtable $tbl -count] connections / limit: $limit)" }
- midhun_108442NimbostratusHi Aaron/Thomas,
- hooleylistCirrostratusTry Hamish's example for 10.1 or higher:
- midhun_108442NimbostratusHi Aaron,
- hooleylistCirrostratusI think this should work if you've defined the host/network = limit pairs in the conn_limit_dg data group.
when RULE_INIT { This defines how long is the sliding window to count the requests. This example allows 10 requests in 3 seconds set static::windowSecs 3 set static::timeout 30 } when CLIENT_ACCEPTED { Max connections per client IP set limit [class match [IP::client_addr] equals conn_limit_dg] log local0. "[IP::client_addr]: \$limit: $limit" } when HTTP_REQUEST { if { [HTTP::method] eq "GET" } { set getCount [table key -count -subtable [IP::client_addr]] log local0. "getCount=$getCount" if { $getCount < $limit} { incr getCount 1 table set -subtable [IP::client_addr] $getCount "ignore" $static::timeout $static::windowSecs } else { log local0. "[IP::client_addr]: exceeded the number of requests allowed. $getCount / $limit" HTTP::respond 501 content "Request blockedExceeded requests/sec limit." } } }
- hooleylistCirrostratusHi Midhun,
when RULE_INIT { This defines how long is the sliding window to count the requests. This example allows 10 requests in 3 seconds set static::windowSecs 3 } when CLIENT_ACCEPTED { Max connections per client IP set limit [class match -value [IP::client_addr] equals conn_limit_dg] log local0. "[IP::client_addr]: \$limit: $limit" } when HTTP_REQUEST { if { [HTTP::method] eq "GET" } { set getCount [table key -count -subtable [IP::client_addr]] log local0. "[IP::client_addr]: getCount=$getCount" if { $getCount < $limit} { incr getCount 1 table set -subtable [IP::client_addr] $getCount "" indefinite $static::windowSecs } else { log local0. "[IP::client_addr]: exceeded the number of requests allowed. $getCount / $limit" HTTP::respond 501 content "Request blocked. Exceeded requests/sec limit." } } }
- hooleylistCirrostratusSorry for missing this... the class match command was missing the -value flag so it was just returning 1 for true (meaning the client IP was found in the data group). Using the -value flag indicates class match should return the value for the corresponding data group key. I've edited my post above with the update. Can you try that instead?
Â
