David_M's avatar
David_M
6 years ago
Solved
Health monitor with login check and content length
I found SOL : https://support.f5.com/csp/article/K1033?sr=58157087
It says:
To create an HTTP 1.1 post, use the following syntax:
POST /MyApp.cgi HTTP/1.1\r\nHost: host.domain.com\r\nConnection: Close\r\nContent-Length: 10\r\nAuthorization: Basic <string>\r\n\r\0123456789
In this syntax, note the following: <string> is the output from step 1
For example:
POST /MyApp.cgi HTTP/1.1\r\nHost: host.domain.com\r\nConnection: Close\r\nContent-Length: 10\r\nAuthorization: Basic ZjU6ZjVwYXNzd2Q=\r\n\r\0123456789
In these examples, your content length of 10 would match the length of your message body, which in this example is 0123456789.
You do not need to specify a user name and password in the monitor configuration when performing this workaround.
What exactly is the last message body part? Why is it required and what value do we need to use there?
Is it just some placeholder to simulate a real request?
