Header replacement irule
Attempting to replace the host header with the FQDN of the node being load balanced to. I found the following iRule in another post however something isn't correct. when HTTP_REQUEST_SEND {
clientside {
HTTP::header replace Host "[LB::server addr]:[LB::server port]"
Error: TCL error: /Common/header - invalid command name "HTTP::u&8221" while executing "HTTP::u&8221"invalid peer expression (line 5) invoked from within "clientside { Replace the HTTP host header with the selected server IP and port HTTP::header replace Host "[LB::server addr]:[LB::server..."
What am I missing here?
- crodriguezRet. Employee
HTTP_REQUEST_SEND is a server-side context event. You could try this instead:
when LB_SELECTED { HTTP::header replace Host "[LB::server addr]:[LB::server port]" }
