Satoshino's avatar
Satoshino
Icon for Cirrus rankCirrus
Oct 02, 2020
Solved
Custom Header Monitor UDP
Hello,
I need to create a Monitor UDP that use custom header in payload (this: STUN Message type: 0x0001; Message Length: 0x0000; Magic Cookie:  0x2112A442), how i could get it?
It's better to use send string or to create a specific Irule?
I don't know where to start.
Thanks you a lot
  • Try hex send string.
    This article is for TCP. but I guess the same is for UDP:
    https://support.f5.com/csp/article/K01524704
