anujg27_358584's avatar
anujg27_358584
Apr 14, 2018
Solved
F5 Fundamental Lab-can't communicate between servers
Hi, I am currently following CBT Lab for F5 fundamentals(see attached 2 images) in which F5 imported and configured on Vmware workstation( Ver 13.x).The Internal subnet is 10.2.0.0/24 and Internal IP address on F5 is 10.2.0.145. My question relates to the INTERNAL section of the diagram where there are 3 web server nodes (10.2.0.11, 10.2.0.22 and 10.2.0.33) which I can't ping from F5. All three nodes can ping with each other. Also F5 internal side and all three web servers are all on Vmnet2.
I would appriciate if somebody can assist me as I have reached a road block.
Anuj
  • Hi Anuj,
    To me, it looks like VMnet issue rather then the F5 issue. Try swapping VMnet2 with other interfaces.
