Magnum_IP
May 04, 2011Error clearing irule stats using bigpipe
Can't figure this one out.
I want to clear the stats on all iRules in partition PART1, I make sure I am in the correct partition and issue what I think is the correct command but I get an error saying the current update partition is Common.
[me@bigip:Active] ~ b shell partition PART1
SHELL - partition: PART1 (read) PART1 (write)
[me@bigip:Active] ~ b rule all stats reset
BIGpipe unknown operation error:
01070826:3: Current Update Partition Error: The current update partition (Common) does not match the object's partition (PART1), stats not reset
Can anyone help?
fergu5
- Colin_Walker_12Historic F5 AccountWhat version are you running on?
Colin - Magnum_IP
BIG-IP 10.2.0 Build 1755.1 Hotfix HF1
fergu5 - Michael_Yates
I am seeing the same behavior when attempting to reset stats in any other partition other than Common.
You might want to open up a case with F5 for an RFE or Fix Action for this.
