rjordan's avatar
rjordan
Oct 07, 2011
Disabling Reject Unmatched Packets vs Dropping with a Packet Filter
We have several virtual servers that require external auditing/scanning for various compliance certifications. Some of our compliance vendors assume that the open/filtered state from dropped UDP packets on our routers are indeed open because they get a closed state from rejected packets from the LBs. It is a pretty bad assumption, but we have to deal with it anyway.
I know I can enable the packet filter to explicitly permit the necessary ports and then set Unhandled Packet Action to DISCARD. I'm just worried that I might miss something in my rules and break a bunch of stuff.
The other alternative seems to be setting TM.RejectUnmatched to False. My concern is that I don't know all the scenarios that RSTs are used for. I guess if a client somehow gets out of sync and sends a SYN that it no longer has a connection for, the LB would not send a RST. It would just allow the client to time out? Is anyone else using this option? It is much easier to implement but I don't know if I should be worried any other side effects.
  • not sure if i understand correctly. u don't want bigip to send reset or unreachable if port is not opening (listening), do u?
    if so, is wildcard virtual server with discard action helpful?
    [root@iris:Active] config  b virtual list
    virtual bar {
       snat automap
       destination 172.28.17.33:http
       ip protocol tcp
       rules myrule
       profiles {
          http {}
          tcp {}
    [root@iris:Active] config  b db|grep -i match
    TM.ContinueMatching = false
    TM.RejectUnmatched = true
    [root@iris:Active] config  tcpdump -nni 0.0 host 172.28.16.50
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on 0.0, link-type EN10MB (Ethernet), capture size 108 bytes
    18:02:39.077784 IP 172.28.16.50.44906 > 172.28.17.33.53:  30724+ A? www.google.com. (32)
    18:02:39.077824 IP 172.28.17.33 > 172.28.16.50: ICMP 172.28.17.33 udp port 53 unreachable, length 36
    [root@iris:Active] config  b virtual wildcard destination any:any mask 0.0.0.0 rule discard_rule
    [root@iris:Active] config  b virtual wildcard list
    virtual wildcard {
       destination any:any
       mask 0.0.0.0
       rules discard_rule
    [root@iris:Active] config  b rule discard_rule list
    rule discard_rule {
       when CLIENT_ACCEPTED {
            discard
    18:04:12.533123 IP 172.28.16.50.58033 > 172.28.17.33.53:  1454+ A? www.google.com. (32)
    18:04:17.533315 IP 172.28.16.50.58033 > 172.28.17.33.53:  1454+ A? www.google.com. (32)
    18:04:22.533661 IP 172.28.16.50.58033 > 172.28.17.33.53:  1454+ A? www.google.com. (32)
    3 packets captured
    3 packets received by filter
    0 packets dropped by kernel
