HA13029's avatar
HA13029
Dec 11, 2017
Datagroup and switch command
Hello,
I created different datagroup (list of TCP ports) and based on this setting, selecting the correct pool within my irule.
ltm data-group internal DG_TCP-010901-10902 { records { 10901 { } 10902 { } } type string }
when CLIENT_ACCEPTED { switch [TCP::local_port] { DG_TCP-010901-10902 { pool P_010901-10902 } etc etc default { reject } } }
Unfortunatly, it doesn't work...
If I change the irule to the following it works... when CLIENT_ACCEPTED { switch [TCP::local_port] { "10901" { pool P_010901-10902 } "10902" { pool P_010901-10902 } etc etc default { reject } } }
Regards,
I prefer to use the switch command instead of if commands and using datagroup to avoid mistake when editing irule...
HA
  • You cant really use datagroups in a switch statement (unless you nest an
    if
    within the switch)
    To look up a datagroup you'll need to use the
    class
    command
        if {[class match [TCP::local_port] equals "DG_TCP-010901-10902"]} {
            reject
  • You can try with this code:
            "10901" -
            default { reject }
    or use a data group containing pool name as value
    ltm data-group internal DG_TCP {
        records {
            10901 {P_010901-10902}
            10902 {P_010901-10902}
            XXXX {P_XXXX}
        type string
        if {[set pool [class match -value [TCP::local_port] equals "DG_TCP"]] ne ""} {
            pool $pool
            reject
  • Hi,
    Thanks Stanislas, it works fine !!
    Regards
    Hedi
  • One last question... Can I use datagroup to reference some URLs (sometimes with wildcard) and based on the result, select the correct pool ?? Example : if the uri match /000552/1743* then select the pool P_0005521743 What's the irule looks like ??
    Regards,
    HA
  • Hello,
    Do you think it's ok with the following ??
    ltm data-group internal DG_URI { records { "/000042/16001" {pool P_name } } type string }
    when HTTP_REQUEST { if {[set pool [class match [HTTP::uri] starts_with "DG_URI"]} { pool $pool } else { pool default } }
    Regards,
    HA
