Stefan_Engel's avatar
May 19, 2020
Solved
Daemons monitoring (13.x)
I'm looking for some clarification on deamons monitoring in 13.x.
Until 12.x this was automatically done by the system (https://support.f5.com/csp/article/K69933022)
  • The BIG-IP 12.x software branch uses the runsv utility to monitor specific daemons. The runsv utility monitors specific daemons and will restart the daemon in the event of a system failure.
I couldnt find any related information for 13.x. In general we just have to decide if we have to monitor specific deamons ourselves or not. If this is "built-in" even better.
Appreciate your feedback.
  • Yes, more recent releases of the BIG-IP software (through 15.1.x, anyway) still use the "runsv" facility.
    Whenever you find that some article in "AskF5" seems to need updating, if you are logged in, you can find a feedback section at the bottom of the web page, with the title "Was this information helpful?" You can enter a comment right there, to ask if the information applies to more recent releases. The appropriate F5 employees will receive it.
