dsirrine_23403
Feb 07, 2011Custom monitor for SMTP servers
I have dug through some of the forums and have yet to find the solution I'm looking for. I have a set of load balanced SMTP servers in my LTM with version 9.3.1 software installed. I have the SMTP health check enabled, however, it doesn't do exactly what I would like it to do. For example, I would like the F5, as part of the health check, to send an actual e-mail to the SMTP server and monitor the response to determine if the e-mail was successful or failed. I recently had an issue where /var on one of the systems filled up, and while the server was still responding to SMTP requests as one would expect, it was failing to accept any e-mails due to the drive being full. I would like the check to disable a node if it fails to receive an e-mail. If you could point me in the right direction, it would be greatly appreciated. Thank you in advance.
- Chris_Miller
Altostratus
Interesting. So, you'd basically like the check to connect to the server, issue a helo, a mail from, an rcpt to, and if it sees "queued for delivery" or whatever, consider it up? Does your mail server have any sort of spam protection which would limit the amount of connections from a single IP? - hoolio
You could potentially do this with a scripted monitor using expect. Or if that doesn't work, an external monitor calling a shell script should do it.
Aaron
- dsirrine_23403
@Chris. That's exactly what I'm trying to accomplish. While knowing port 25 is listening is nice and important, I need to also determine if the server is accepting mail. I'm looking to ensure I get a 250 response code essentially.
@Hoolio: Thanks for the info. I'll look into this. - dsirrine_23403
I think I can do this with the send/expect. However, how can I set a variable to be the IP of the node that is running the check. For instance, I have two SMTP servers in my LTM, I create the expect to be something like the following:
send telnet 25
expect 220
send ehlo
expect 250
send mail from:
expect 250
send rcpt to:
expect 250
send DATA
expect 354
send Test
send .
expect 250
Essentially, I want my F5 to disable the node if it gets anything but a 250 or 354 at any point in this session. - dsirrine_23403
whoops. It did some code cleaning. there should be ip_address between telnet and 25 as well as after ehlo. And email_address after from and to - dsirrine_23403
I got it to work. I didn't need the initial "send telnet" as the scripted monitor does that to begin with. Unfortunately, I can't use pop/imap/etc as this is to test an exim gateway and can't necessarily "retrieve" the e-mail from the impacted system. doing an "ehlo" on localhost rounds it out nicely. Here's what I ended with:expect 220 send "HELO localhost\r\n" expect "250" send "MAIL FROM: @localhost\r\n" expect "250" send "RCPT TO: @localhost\r\n" expect "250" send "DATA\r\n" expect "354" send "SUBJECT:F5 LTM SMTP Health Check\r\n" send "\r\n" send "This e-mail is generated by the SMTP health check by the F5 LTM.\r\n" send ".\r\n" expect "250" send "quit\r\n" expect "221"
where
= a local account that the mailbox has been redirected to /dev/null. If /var is full, I get an error of not being able to write to spooler, otherwise, I get a 250 OK. - hoolio
Thanks for the solution dsirrine. I added it to the Codeshare here:
http://devcentral.f5.com/wiki/default.aspx/AdvDesignConfig/SMTP_scripted_monitor.html
Aaron - Techgeeeg
This script was written for which MS Exchange2010 or earlier.... and is it expected to work with all the MS & TMOS platform or only the selected ones.
Regards, - hoolio
Hi Techgeeg,
The scripted monitor should work with any SMTP server.
Aaron - Torsten_93742
Hi, the links in this post are outdated:
External monitor template: https://devcentral.f5.com/wiki/AdvDesignConfig.TemplateForExternalLtmMonitors.ashx
SMTP monitor at Codeshare: https://devcentral.f5.com/wiki/AdvDesignConfig.SMTP_scripted_monitor.ashx
Cheers, Torsten
