Custom HTTPS External Monitor
Problem this snippet solves:
Contributed by Leonardo Souza.
This monitor works around limitations with built-in monitor in selecting tls version for server monitoring. Details in this article.
Code :
#!/bin/sh
# Leonardo Souza - 20/10/2016
# HTTPS External Monitor
# Version 1.0.0
# Using openssl s_client because curl only accepts tlsv1.0/tlsv1.1/tlsv1.2 from version 7.34.0 (v12.1.1 HF1 uses 7.19.7 for example)
# For protocol and cipher options go to this link:
# https://www.openssl.org/docs/manmaster/apps/s_client.html
# External Monitor example
#ltm monitor external https_monitor {
# defaults-from external
# destination *:*
# interval 5
# run /Common/https_external_script
# time-until-up 0
# timeout 16
# user-defined cipher DEFAULT
# user-defined debug enable
# user-defined protocol tls1
# user-defined receive_string Welcome
# user-defined receive_string_down Moved
# user-defined send_string "GET /"
# If debug mode is enabled, log to /var/log/ltm
# debug=enable to enable debug, debug=disable to disable debug
# If debug variable is not set, debug will be disabled
# File to save OpenSSL output
output=`mktemp`
# File to save OpenSSL output error
output_error=`mktemp`
# Variable to save OpenSSL output exit code
output_code=""
# Variable to store the monitor result
result=""
# $1 = Pool member IP in IPv6 format, need to remove :ffff:
# $2 = Pool member port
ip=${1/#::ffff:}
port=$2
# Script name
script=`basename $0`
# Script pid
pid="/var/run/$script-$1:$2.pid"
# Check if there is any instance of the script running
# Kill the instance if is running
# Create pid file
[ -f "$pid" ] && kill -9 `cat $pidfile` > /dev/null 2>&1
echo "$$" > $pid
# OpenSSL command
echo $send_string | openssl s_client -quiet -$protocol -cipher $cipher -connect ${ip}:${port} 1> $output 2> $output_error
output_code=$?
# If receive_string or receive_string_down is not defined, mark pool member up as long as OpenSSL command was successful
if [ $output_code -eq 0 ]
then
result="up"
[ $debug = "enable" ] && logger -p local0.notice "$script ${ip}:${port} - OpenSSL: Pool member up" &> /dev/null
else
result="down"
if [ $debug = "enable" ]
then
logger -p local0.notice "$script ${ip}:${port} - OpenSSL: Pool member down" &> /dev/null
logger -p local0.notice "$script ${ip}:${port} - OpenSSL: `cat $output_error | head -n1`" &> /dev/null
logger -p local0.notice "$script ${ip}:${port} - OpenSSL: `cat $output_error | tail -n1`" &> /dev/null
fi
fi
# If receive_string_down is set, perform some tests
# If string is not in the output, mask pool member as up
if [ -n "$receive_string_down" ]
then
cat $output | grep "$receive_string_down" &> /dev/null
if [ $? -ne 0 ]
then
result="up"
[ $debug = "enable" ] && logger -p local0.notice "$script ${ip}:${port} - Receive String Down: Pool member up" &> /dev/null
else
result="down"
[ $debug = "enable" ] && logger -p local0.notice "$script ${ip}:${port} - Receive String Down: Pool member down" &> /dev/null
fi
fi
# If receive_string is set, perform some tests
# If string is in the output, mask pool member as up
# If string is not in the output, mask pool member as down
if [ -n "$receive_string" ]
then
cat $output | grep "$receive_string" &> /dev/null
if [ $? -eq 0 ]
then
result="up"
[ $debug = "enable" ] && logger -p local0.notice "$script ${ip}:${port} - Receive String: Pool member up" &> /dev/null
else
result="down"
[ $debug = "enable" ] && logger -p local0.notice "$script ${ip}:${port} - Receive String: Pool member down" &> /dev/null
fi
fi
# Remove temporary files
rm -f $output
rm -f $output_error
# Remove pid file
rm -f $pid
# echo result is up
[ $result = "up" ] && echo "up"Published Oct 27, 2016
Version 1.0JRahm
Admin
Christ Follower, Husband, Father, Technologist. I love community and I especially love THIS community. My background is networking, but I've dabbled in all the F5 iStuff, I'm a recovering Perl guy, and am very much a python enthusiast. Learning alongside all of you in this accelerating industry toward modern apps and architectures.No CommentsBe the first to comment
