Counting and limiting HTTPS sessions
The website I am writing an irule for runs both http and https. I am following this irule to count http requests sessions HHTP Session Limit to redirect if the session count is high. I have this working mostly.
Now I need to deal with SSL connections. How can I count SSL connections using an irule? I take it the httpp_request will not count https connections so wondering what the best way to do this is.
Any help would be greatly appreciated.
Oli
- Kevin_Stewart
Employee
If you're offloading the SSL with a client SSL profile, then you can absolutely use the same HTTP iRule on the HTTPS VIP.
- Kevin_Stewart
Employee
As long as you can see the HTTP payload, having offloaded SSL on the client side, it doesn't matter what you do on the server side.
- Oli_138142
great - thank you.
