BJ_114988's avatar
BJ_114988
Nov 26, 2018
Solved
confused! not sure what is difference between these commands
what is difference between curl , openssl and WGET ?
when to use these commands ?
as all commands basically used to test ssl on server or VIP. is ther any difference in ciphers that they used.
i read that they use some different ssl libraries. is it true ?
  • Hi BJ ,
    what is difference between curl , openssl ?
    Ans. Curl is a tool to transfer data from or to a server, using one of the supported protocols (DICT, FILE, FTP, FTPS, GOPHER, HTTP, HTTPS, IMAP, IMAPS, LDAP, LDAPS, POP3, POP3S, RTMP, RTSP, SCP, SFTP, SMB, SMBS, SMTP, SMTPS, TELNET and TFTP). The command is designed to work without user interaction.
    So basically if your application server supports http ( non - encrypted) data , you can fetch or send http data to or from a server. During use of this command it allows you to manually set ciphers and test . For example. - curl -kv --sslv2 -- ciphers AES128-SHA https://10.1.1.1:443
    OPENSSL - If you familiar with command line of f5 , you can use this feature to change certificates formats , generate cert etc.This is only for SSL related purposed and has limitations.
  • Could you please tell what is the difference between SSL ciphers that are used in openssl and curl ?
    how does it decides which cipher suite to use and send to client during SSL handshake for negotiation ?
