Techgeeeg_28888
Jan 24, 2012Citrix 6.0 problem in accessin via LTM Ver11.1.0
Hi Everyone,
I have recently upgraded our LTM environment from 10.2.2 to 11.1.0 and the setup is good but my Citrix environment started showing some problem.I will list them below,
1. As per the Implementation guide for Citrix on v11. The code that we have to change to get the client IP details when its changed on the Citrix servers and the application is accessed via VIP it gives the message that the servers are not available. On putting the code back to what it was everything starts working fine.I need to understand what is the problem causing this.
2.The iAPP using the citrix template creates one pool called citrix_enumeration and created a tcp based monitor for it. This automatically created monitor bring this pool down. when removed and assigned a simple udp monitor everything starts working well. I need to understand what is the problem causing this.
3. Finally when the user hits the Citrix Web server VIP and logs in successfully and clicks on any of the application on the first click it returns an error to the user saying "your resource you have requested can't be found" when clicked again it invokes. I am not able to find a way to fix it.
This simple setup was working perfectly fine on ver 10.2.2 but it has like a never ending issue on this new 11.1.0 ios platform can any one help me out in this matter.
Regards,
- Posted By Techgeeeg on 01/24/2012 09:17 AM
Hi Everyone,
Can you please clarify this issue? There is absolutely nothing you would've had to change on your Citrix Web Interface/XML broker farm to have it load-balanced in v11 vs. v10.2.x - if the Implementation Guide suggestions otherwise, please let us know exactly where/what and ignore those suggestions for now.
It is possible that your Citrix servers have port 137 locked down and not responding to TCP? If this port is not enabled, it can cause slowdown/inability to launch appications. See the Citrix article here: http://support.citrix.com/article/CTX118670
Can this be as a result of any changes to the Citrix Web Interface/XML broker servers you did in issue 1? I think this is related to either 1 or 2 above. Can you launch the application when going directly to the Web Interface server? If not, then F5 is not a likely culprit here
Regards, - Techgeeeg
Hi Michael,
Good to see your reply let me answer you one by one,
1. For my first point I am talking about the deployment guide available at the link http://www.f5.com/pdf/deployment-guides/citrix-xenapp-iapp-dg.pdf and I am particularly talking about the changes asked to be done on page no. 10 of this deployment guide so i hope this point must be clear to you.
2. For point no. two non of the ports are blocked as it is a plan LAN so the servers can be accessed directly there is nothing sitting in the middle blocking any thing.
3. The web and XML broker servers when accessed directly are working perfectly fine. So the issue is there on F5 box that is for sure
I have done like almost all the possible combination of tests to make sure if the problem is on the Citrix setup but no it is not the problem pop ups only when coming via LTM....
The same setup was working fine on version 10.2.2 but it has issues on version 11.1.0
Kindly let me know if you can help me out in this matter....
Regards, - Posted By Techgeeeg on 01/24/2012 10:48 AM
Hi Michael,
Right - so you should've pointed your Web Interface to go through the new VIP for XML broker - that's the only main change necessary.
Sorry, upon further investigation, it appears that there is a bug - there should be a UDP monitor instead of TCP one - this will be addressed in the updated version of the iApp.
3. The web and XML broker servers when accessed directly are working perfectly fine. So the issue is there on F5 box that is for sure .
Please go and remove Compression, Caching, and NTLM/OneConnect profiles from the XML broker virtual if they are assigned and try again, please.
Regards,
