veredgfbll's avatar
Mar 03, 2024
binding issues - ldap monitor
I have set up an ldap monitor for a pool using TCP 636.
No matter what I do, it doesn't work.
I set up the user name: cn=username,ou=xxx,dc=yyy
set the password
set the Base: ou=xxx,dc=yyy
set a filter: filtername=username
I have tried setting it with all ports and with port 636 and even the standard ldap port (389). Also tried without the base, and also with no base and no filter.
No matter what I try, the debug log keeps showing :
Bind failed with username(-1): Can't contact LDAP server
What am I missing?
This isn't an active directory ldap - so maybe this is the issue?
Any ideas would be very much appreciated.
Thanks,
Vered
  • Recently I had a problem related to filter, and KB https://my.f5.com/manage/s/article/K07347450 helped me. In your case it seems like its not related to the absence of the filter. Have you tried to authenticate using same parameters but with another ldap tool? like ldapsearch of something?
