am_gli_287451's avatar
am_gli_287451
Mar 01, 2019
APM: Reauth required for different URL on same listener
short question: I have an APM authentication policy bound to a listener. There is a Sharepoint published via the listener. If you connect to sp.acme.com, you get the login form and can access it afterwards.
The sharepoint has a default url "sp.acme.com" and if you upload a pic, it is stored in "pics.acme.com". The problem is, the pics are not shown properly as content on the sp-page. If you open the pic in another tab, you are redirected to the logon-page of "pics.acme.com". If you authenticate there, then the pic is shown properly.
So my question now is - how could I achieve a single-login for all pages/subdomains that are running on that listener, and not to have a login mask again.
Is there any guide to this? On SP directly (without F5 in between), this works properly.
I assume ther is something with the SSO/Auth Domains in the Access Profile?
Thanks in advance!
  • You're right!!! this is in SSO / Auth domains in Access profile...
    You have 2 solutions:
    • define the domain acme.com in SSO domain field
    • define multiple domains SSO with:
      • logon URL : login.acme.com
      • domain / host : sp.acme.com
      • domain / host : pics.acme.com
    The problem with the first solution is all web sites hosted on the acme.com domain will receive the APM session cookie which may cause security issue!
