IVD's avatar
IVD
Oct 05, 2024
Solved
APM issue errorcode=19
hi,
For lagacy purpose, I need to create an APM on my VS.
I don't understand why but applying any Access Policy on my VS result on an errocode=19 "access denied"
The VS is a basic HTTP Virtual server
IP xxx.xxx.xx.xx
Listen adress 80
Pool redirecting to a single host
Protocol tcp
protocol client & server tcp
HTTP Profile client & server http
VLAN & SNATPOOL Defined
No Irule, Nor perstence profile
When i don't enable the APM the VS is working as expected
I've reduced The Access Policy to the simpliest,
Start --> Allow
And set the SSO Auth Domains - Cookie Options  to HTTP Only
Any help would be appreciated
  • This error means that the user's browser:
    1- Accessed an APM virtual.
    2- Got a 302 to "/my.policy" with a cookie to use for that request.
    3- Accessed "/my.policy" without the cookie they just got.
    Like most web apps, APM's session management relies on cookies. By default APM's cookies have the "secure" flag.
    To understand the issue more fully you can read about how cookies work, especially read the part about the secure flag:
    https://developer.mozilla.org/en-US/docs/Web/HTTP/Cookies#block_access_to_your_cookies
    • IVD's avatar
      IVD
      Thank you it was helpfull,
      The issue was with my client application that wasn't accepting the cookie.
      I found out that i should use the Header clientless-mode for my application to be able to authenticate.
      Thanks for your help
