blacksan_10396
Jun 15, 2011APM - Web Application Split Tunnel
Does anyone have any examples to create a split-tunnel environment like the Firepass?
I am trying to create the following scenario which is easy with the Firepass:
1: Split-Tunnel ACL - example: www.f5.com
2: Rewrite ACL - example: *.f5.com
3: Default Rewrite Rule - Bypass Rewrite Engine like links on devcentral.f5.com to www.gartner.com
4: Deny ACL - example: devcentral.f5.com/adminconsole
5: Allow ACL - example: devcentral.f5.com
6: Default ACL - Deny All - this will block support.f5.com but not www.gartner.com
So far the APM is a little reversed concept:
1: Default Rewrite Rule - Rewrite everything
2: Application Web Application ACL
3: Flexible L7 ACL
I am assuming I can use I-Rules REWRITE_RESPONSE_DONE but I don't know the command to ignore the Rewrite Engine for weblinks.
1: Create a datagroup to bypass ACL = www.f5.com
Scan website for links and compare to datagroup like
if { [matchclass bypass-web-group equals "$[HTTP::host]"] }
Do not Rewrite links
2a: Create Application Web Application for all websites which needs to be rewrite - *.f5.com over 80/443
2b: Create a Datagroup which matchs the ACL on Web Appliation
3: Next level of I-rule will scan website for links and compare to the next datagroup like
if { [matchclass rewrite-web-group not equal "$[HTTP::host]"] } - Rewrite all other links - www.gartner.com
4: Create a ACL to block like devcentral.f5.com/adminconsole
5: Create a ACL to Allow website like devcentral.f5.com
6: Create a Bottom-ACL to block all websites
If we can't control Rewrite engine, is there a way to inject around the web-links before it gets to the APM?
