Mike_Maher
Apr 09, 20122-Way SSL issue on v11.1
I have box that I upgraded from v10.2.0 HF 2 to v11.1 HF 2, and now all the applications that have server side 2 way ssl are not working. I have a case open with support to look into this, but I thought I would see if anyone has any suggestions. I have turned off re-negotiation so that should not be the issue. It appears that when I look at the ssldump that after the ServerHelloDone I see the ASM send a RST. I have 4 applications that connect to different web servers on the back end that perform 2 way ssl (client cert auth) and none of them are working so something is wrong with the configuration. Has anyone had any experience with this?
- Techgeeeg
Hi Mike,
I have come across a similar sort of issue and what i have found up to now is that the uploaded ssl.crt and ssl.key are missing from the folder where they should be listed why this is happening I have no idea but i believe this is the main reason this problem is happening let the support help you in this I am also waiting for them to revert back to me and help me out.
Regards, - nitass
Employee
mine is 11.1.0. i do not configure trusted certificate authorities in serverssl profile since i think it might not be relevant.root@ve1110(Active)(/Common)(tmos) show sys version Sys::Version Main Package Product BIG-IP Version 11.1.0 Build 1943.0 Edition Final Date Sun Nov 20 18:27:50 PST 2011 root@ve1110(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.19.252:443 ip-protocol tcp mask 255.255.255.255 pool foo profiles { clientssl { context clientside } myserverssl { context serverside } tcp { } } snat automap vlans-disabled } root@ve1110(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 172.28.19.79:443 { address 172.28.19.79 } } min-active-members 1 } root@ve1110(Active)(/Common)(tmos) list ltm profile server-ssl myserverssl ltm profile server-ssl myserverssl { app-service none cert client.crt defaults-from serverssl key client.key } accessing pool member directly [root@ve1110:Active] config curl -Ik https://172.28.19.79 curl: (35) error:14094410:SSL routines:SSL3_READ_BYTES:sslv3 alert handshake failure [root@ve1110:Active] config curl -Ik https://172.28.19.79 --cert /var/tmp/client.crt --key /var/tmp/client.key HTTP/1.1 200 OK Date: Sat, 14 Apr 2012 07:40:21 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT ETag: "4183e4-3e-9c564780" Accept-Ranges: bytes Content-Length: 62 Content-Type: text/html; charset=UTF-8 accessing virtual server [root@ve1110:Active] config curl -Ik https://172.28.19.252 HTTP/1.1 200 OK Date: Sat, 14 Apr 2012 07:40:37 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT ETag: "4183e4-3e-9c564780" Accept-Ranges: bytes Content-Length: 62 Content-Type: text/html; charset=UTF-8
