atoth's avatar
atoth
Icon for Cirrus rankCirrus
Oct 20, 2015
2-Way SSL Authentication with irules.
I've got a requirement to implement an irule on an vip, which would redirect traffic to another vip on the same LB, based on a simple uri. Easy-peasy, right? However, it turns out that the customer is using two-way SSL authentication. Now this thread( https://devcentral.f5.com/questions/2-way-ssl-implementation-25325 ) was most helpful, but I still have a few questions.
  • 1)The customer's SSL certificate is self-signed. From what I understand, this won't fly, and they must get a certificate with an intermediate cert bundle that can be installed on the F5. Correct?
  • 2)All the modifications take place on the client profile. I need to set Client Authentication to request or require and specify the intermediate cert bundle in this section as well.
  • 3)Can I set a server ssl profile on the originating vip(VIP1). VIP2, doesn't have ssl traffic offloading enabled.
  • 4)If I can't set a server ssl profile on VIP1, what happens to the default traffic will is going to the pool under VIP1?
  • Comments inline.
    The burden of trust here is on the client in this case, so you technically can use a self-signed server certificate, but NEVER a best practice.
    Correct. The Client Authentication option will set the VIP to request a client certificate (mutual PKI authentication). The settings dictate what happens if the user doesn't provide a certificate or if certificate validation fails. Request is a "fail open" and Require is a "fail closed". The Trusted Certificate Authorities option in a single or bundle of certificate authority (CA) certificates. This needs to be the complete chain of CAs up to and including the self-signed root CA.
    A server SSL profile is only needed if you need to re-encrypt to the server. It has no bearing on client side mutual authentication.
    It won't be encrypted.
